[SOLVED] Advice with first pc-build
Aug 30, 2021
13
Hi everyone,
I finally decided to build my first pc after wanting it for so long. I've put together a list with components for my pc-build. I would like to get some advice on it, since it is my first time building one. I really don't want to get anything wrong (mismatches/components which are not compatible).
See below the link to pcpartpicker.com:
https://pcpartpicker.com/user/musiboyy/saved/tTz4Mp
I couldn't find the case I want to buy on this site, so below is the link also for the case:
https://www.alternate.nl/Lian-Li/O11-Dynamic-MINI-behuizing/html/product/1710388
Any advice or comments will be really appreciated!
Thanks in advance!
Kind regards,
Musi
The reason it didn't show up, is that case requires an SFX power supply, and you chose a standard one. Compatibility mode will filter out incompatible parts. You want DDR4 3600 CL16. CL18 will give you the same performance, as a cheaper DDR4 3200 CL16 kit. Do you need PCI-E gen 4, for storage? Games really don't take advantage of that speed. If I was spending that much money, on a drive, it would be a 2tb Gen 3.0. Games are becoming quite large.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($272.99 @ Amazon)
CPU Cooler: Vetroo V5 52 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard ($155.00 @ Amazon)
Memory:...
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory ($84.99 @ Amazon)
Storage: Team T-Force Cardea Zero Z330 2 TB M.2-2280 NVME Solid State Drive ($199.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 3060 Ti 8 GB GAMING OC Video Card
Case: Lian Li O11 Dynamic Mini ATX Mid Tower Case ($105.99 @ Newegg)
Power Supply: Cooler Master V SFX Gold 850 W 80+ Gold Certified Fully Modular SFX Power Supply ($144.99 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($139.88 @ Other World Computing)
Total: $1133.82
Generated by PCPartPicker 2021-08-30 11:34 EDT-0400
Total: $1133.82
____
Thank you for your advice. I am going to adjust the SSD and RAM like you suggested. Just one more question about the case/power supply:
I changed the case in the following:
https://www.alternate.nl/Lian-Li/O11-Dynamic-tower-behuizing/html/product/1710556
Will the previous Power Supply now fit, since this case also has ATX compatibility?
Thank you again.
The problem I have with the O11 dynamic, is no fans. So unless you intend on buying a lot of fans, it might not be the best choice. Nonetheless, here is one with an actual ATX PSU.
Case: Lian Li PC-O11 Dynamic ATX Full Tower Case ($139.99 @ Newegg)
Power Supply: Antec High Current Gamer Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Newegg)
Total: $1122.82
Generated by PCPartPicker 2021-08-30 15:00 EDT-0400
If you are unable to buy the extra fans, you might want to consider one of these Lian-li cases.
Total: $1122.82
_
Thank you for your response once again!
I am able to buy extra fans. I was thinking about the following fans:
- Lian-Li ST120 RGB (3-pack fans) (link: https://www.alternate.nl/html/produ...m_campaign=Tweakers_Case fan&utm_term=1711487
- Lian Li UNI FAN SL140 (1 fan) (link: https://www.alternate.nl/html/produ...m_campaign=Tweakers_Case fan&utm_term=1711532)
I thought these 4 fans would be enough for the case.
With all the previous components, will there be any incompatiblity issues?
Thank you in advance for your response!
