[SOLVED] Aerocool P7-C1 Pro vertical gpu mount ?
Nov 19, 2020
Specification says that this case support vertical gpu mount.
I see removable side grill near GPU but as I think there should be a mount for riser and gpu on the bottom side. Are there any native aerocool mounting available? Or should I buy mounting from cooler master?
I've gone through the entire product support site and I can't find any mention or illustration of a vertical GPU mount/support for that case. Yes, in order to get a GPU in the vertical orientation, you're going to have to rely on a bracket like that made by CoolerMaster.
