Aerocool Strike x 600w 80+ psu - help
dansontyl
4
hi,
recently I bought a a10 7850k, msi a88x-g45 gaming MB, and also Kingston hyperX 2400mhz 8gb to upgrade my existing PC. (Hard disk 500gb and dvd rom only normal class )
But I plan to change my PSU from CM 500w to Aerocool Strike x 600w 80+ psu. Is it suitable?
I also plan to buy GC R7 260x / 265x in the future.
anyone can help me?
cus in my country this PSU cost is lower than other brands and I wan to try it.
PSU is something you don't want to skimp on, a bad PSU can wreck your system, might take it a year, maybe two, maybe never, but the chance of that happening is greater with lower quality PSUs, I'm sure anyone here will agree, look for Corsair, PC P+C, Seasonic, XFX, Silverstone, Antec, look for these and don't worry about your system. What you're looking for isn't so much enough wattage, though, that is a factor, but clean, stable power. Lower quality PSUs might be labeled 600W, when they mean 600W Peak, which means you should run it at 500 or so. Also, the power fluctuates putting stress on your system. Save and spend the extra bucks to get a good PSU, then use it again in your next system.
