Aerocool Strike-X 600W the problem in my build?
foxmlg
11
I have:
-i7 2600k not OC'd
-4x2GB DDR3 Ram
-MSI GTX 660 Ti Power Edition (Going to get a MSI GTX 770 Gaming next month)
-3 HDD's
-1 SSD Samsung 840 EVO 250GB
-P8H67 M-EVO
-4x 120mm case fans
-1 CD/DVD RW
I had a Halfmman 700W..
And I bought a new case.. and a new PSU..
But since I changed to Aerocool Strike-X 600W, my CPU seems to not work as intended in Real Time Interpolation Softwares like SVP.. its like 30% less performance in that. (I also use GPU OpenCL acceleration).
And on minecraft I can no longer run optifine + 128x Texture Packs.
And sometimes the pc freezes and I need to restart it.
I didnt notice any fps change on BF4, but its possible that there is some change. I just didnt notice it, cus I dont remember how it was. 😛
I didnt have any problems with the other PSU..
*I bought this new PSU because Im going to change to a GTX 770..
If its the PSU fault, What PSU do you guys recomend me to buy, at a price range of 50 to 80€?
And at least 80+ Bronze.
Thz
i can only think that its because you stepped the power down to be honest you should of gone higher since your getting a 770 dropping the psu was a mistake.
have you tried to run your system without the vid card?
My problem isnt the graphics card.. the problem i have is poor CPU performance.. at least thats what it apears to be..
I saw in the PSU box that it says: "Supports Dual Core CPU, ATI Crossfire, NVIDIA SLI and all Multi-Core GPU technologies."
Does that mean it doesnt support 4 core CPUs? maybe thats the problem..?
And can you recommand another PSU, of another brand or something? still at the same price range. ofc. cus here the stores are a bit limited at what brands they can get, and Im not able to make purchases online.
Thz.
I dont need anything above 700W that I know for sure.. lol
Im only going to be running a 660 Ti..
and then a 770..
not both at the same time.
