Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Thanks, again, Jim! I greatly appreciate your help.
Where and how would I place a jumper to turn the PSU ON? The Power Switch?
I'll try the tests again and be sure to make metal-to-metal contact with the
Multimeter.
Are you suggesting that I probe the female socket on the power cord with the
Multimeter set on 120 volts DC while the power cord is plugged into the wall
socket?
The settings on the dial for this Multimeter are limited to 15 volts, 150
volts, and 500 volts. The same holds true for AC voltage settings on the
Multimeter dial.
With kindest regards
Dick Smith
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:%23Ffifn37EHA.1392@tk2msftngp13.phx.gbl...
> You need to have a resistor/jumper to "turn the PSU ON"
> before it will provide voltage to the system.
> You do need to be sure that you're making metal to metal
> commotions inside the connectors.
> I will be busy with the New Year celebrations, so take your
> time, read the instructions and be careful not to damage
> your hardware or injure yourself.
> I would suggest that you double check everything, from using
> the meter on a 120 volt setting to check that the power cord
> is making power avail;able to the PSU and then check on each
> connector for rated voltage.
> Just be careful.
> "AA Smith" <SmithRMS@Comcast.net> wrote in message
> news:ufPXJP37EHA.1204@TK2MSFTNGP10.phx.gbl...
> | Hello, again, Jim;
> | This problem just gets curioser and curioser. I have
> double-checked all
> | wiring connections to the motherboard; all are properly
> connected, including
> | the Power Switch connector and the ATX Power supply
> connection to the ASUS
> | P3V4X motherboard.
> | I took your suggestion on getting the RS Multimeter.
> However, the folks
> | there were not aware of the How to Use book that you
> mentioned. So, I
> | checked Google and found guidelines for testing the 300
> watt ATX Power
> | Supply. With the AC power cord from the wall socket
> plugged into the ATX
> | Power Supply, I set the Multimeter to 15 volts DC (the
> lowest setting
> | available on this Multimeter. I then used the black probe
> to probe one of
> | the black wires in an unused power connector coming from
> the power supply.
> | I used the red probe to probe the yellow wire in the power
> connector. I got
> | no reading at all. I then used the red probe to probe the
> red wire socket
> | on the power connector. Again, I got no reading.
> Incidentally, I did
> | install a good AAA battery in the Multimeter before
> getting started.
> | According to the guidelines I found on the article, that
> meant that the
> | power supply was dead and needed replacement.
> | So, I replaced it with as 400 watt, unswitched power
> supply and made all of
> | the appropriate connections to the motherboard and floppy
> drive, hard drives
> | and CD-ROMs
> | However, the computer still wouldn't start. Absolutely
> nothing happens
> | when I press the power button. No beep, no fans whirring,
> no lights flash.
> | Nada!
> | So I used the Multimeter to probe the 400 watt power
> supply's power
> | connector's black, yellow, and red wires with the
> Multimeter set to 15 DCV.
> | However, the needle did not budge from zero. It produced
> no reading
> | whatsoever.
> | Though it may be the case, I find it hard to believe that
> both power
> | supply's are defective.
> | I shall very greatly appreciate ay further ideas as to
> what might be keeping
> | this computer from starting.
> | Dick Smith
> in message
> | news:utz6hyx7EHA.3616@TK2MSFTNGP11.phx.gbl...
> | > Don't change the subject line, put the questions and
> answers
> | > in the body, please.
> | > PSU do have internal circuit protection, if you're sure
> the
> | > wall outlet has power and nothing happens when you press
> the
> | > power switch, some failure, perhaps a fuse, broken wire
> or
> | > such is the likely problem.
> | > Do any fans or lights work? Any beeps?
> | > You can buy a simple tester/meter for the power supply
> for
> | > $10-20, it might be a good investment and it can be used
> to
> | > check many other things too. Radio Shack has a nice
> little
> | > book on how to use a multimeter Google for "multimeter
> book
> | > radio shack" or "how to use a multimeter."
> | > news:ePhWUIw7EHA.3908@TK2MSFTNGP12.phx.gbl...
> | > | Hello, again, Jim;
> | > | I forgot to mention that I don't have a multimeter or
> volt
> | > meter of any
> | > | kind.
> | > | With kindest regards,
> | > | Dick Smith
> wrote
> | > in message
> | > | news:OwoY70v7EHA.3596@TK2MSFTNGP12.phx.gbl...
> | > | > When you unplugged the power cord from the power
> supply,
> | > is
> | > | > it possible you tripped a circuit break, voltage
> switch
> | > or a
> | > | > fuse?
> | > | > Are you sure the wall socket is powered,too?
> | > | > If you have a multimeter, check the PSU voltages.
> | > | > The people think the Constitution protects their
> rights;
> | > | > But government sees it as an obstacle to be
> overcome.
> | > | > news:ePd8bvv7EHA.2452@TK2MSFTNGP14.phx.gbl...
> | > | > |I have built and upgraded quite a number of PCs in
> the
> | > IBM
> | > | > ATX
> | > | > | architecture.
> | > | > | Today, I moved the internals of a computer that
> has
> | > been
> | > | > successfully
> | > | > | running Windows XP Pro for 2-1/2 years. That
> | > computer's
> | > | > internals include
> | > | > | an ASUS P3V4X Motherboard, 3 ATA-100 hard drives
> (all
> | > | > controlled by an
> | > | > | ATA/100 Promise PCI controller,) a CD-RW drive, 3
> | > CD-ROM
> | > | > drives, a 3COM NIC,
> | > | > | a SoundBlaster PCI card, an AGP video card, and a
> 3
> | > 1/2"
> | > | > floppy drive.
> | > | > | After transferring all internals from my old
> cabinet
> | > to a
> | > | > new one, I powered
> | > | > | the computer up. It booted and started WindowsXP
> Pro
> | > | > successfully, though
> | > | > | prior to starting Windows XP Pro, the motherboard
> boot
> | > | > process indicated
> | > | > | that a problem existed with the floppy drive,
> which I
> | > | > bypassed by pressing
> | > | > | F1. The problem was easy enough to diagnose;
> somehow
> | > the
> | > | > power cable for
> | > | > | the floppy disk drive had come loose from its
> | > | > connector/socket. After WinXP
> | > | > | Pro finished its startup process successfully, I
> | > exited
> | > | > Windows by selecting
> | > | > | Start | Power Off | Power Off. The computer
> powered
> | > down
> | > | > normally.
> | > | > | After disconnecting the power cord from the back
> of
> | > the
> | > | > computer, I replaced
> | > | > | the power cable on the floppy drive's power
> connector.
> | > | > Then, I plugged the
> | > | > | power cord into the back of the computer and
> pressed
> | > the
> | > | > Power button.
> | > | > | However, nothing happened. I checked to be sure
> that
> | > the
> | > | > small wire from
> | > | > | the Power button was still plugged into the proper
> | > | > location on the
> | > | > | motherboard. It was. Nevertheless, the computer
> will
> | > not
> | > | > boot up.
> | > | > | For the moment, I'm not sure what's wrong. I
> don't
> | > know
> | > | > if the 300 Watt
> | > | > | power supply just happened to become defective at
> that
> | > | > time, or if something
> | > | > | is wrong with the motherboard.
> | > | > | So, I shall greatly appreciate your kind help in
> | > figuring
> | > | > out what's wrong.
> | > | > | Dick Smith
