Question After upgrading my PC it doesn’t turn on, the fans only spin for a split second, and it shuts off ?
Nov 2, 2024
56
Okay so this might be quite long... so today I bought new ram (ddr4 vengeance 32gb) to upgrade from my ddr4 veangence 16gb. I also bought a new 1tb sata Kingston ssd. And finally a deep cool ls520 liquid cpu cooler. I installed the ram, the ssd and finally the cooler. However for the installing of the cooler I couldn't manage to find the pin for the 5v D Gnd on my motherboard. However I found a cable around the back that fit it. Also a 5v D Gnd. I knew this prob wasn't the best thing to do and I think but I'm not sure but this might be what broke it.
Anyways I started it up and it just sort of stuttered. The fans spun for like less then half a second and then stopped. I immideatily turned the power off and unplugged all other cables from the cooler to the mobo. I realized that I hadn't installed my got so I tried that and booted it again without the cooler installed and still the same stuttering problem. I switched back to my old ram still didn't work. Did I ruin it or is it save able? Any help or tips would be very appreciated!
View: https://imgur.com/a/5t4SfZe
Lutfij
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
For the sake of relevance, we will need to know the specs to your build before the upgrade and the specs to your build after the upgrade.
There's a saying, just it fits doesn't mean it should go there. To be sure, you should include some images of the cable you speak of. Host it on a site and then pass on the link for us to see.
Could be possible you fried the board with the cable you pulled out from a parts bin but we will need more info.
Nov 2, 2024
56
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Yes that is what I fear.
I5 9600k
Before upgrade be quite, can’t remember the modell, worked well for 3 years
After: deep cool ls520
Asus z390- a pro
Before upgrade, 2x8gb Corsair vengeance ddr4
After upgrade, 2x16gb Corsair vengeance ddr4
Before upgrade- 256gb Kingston ssd - 256 sandisk ssd - 2tb WB hdd - 1tb WB hdd
Asus rtx 2070
Corsair veangence 650
Deepcool matrexx 55
Windows 11
Acer 27, 144hz monitor can’t remember exact modell
The psu is from when I first built my pc a believe 4 or 5 years ago
The bios has not been updated since then.
I will try and post some photos in a sec👍🏼
Lutfij
56
Asus z390- a pro
You sure about the board? MSI have a board with the same naming. Is it this? If so,
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/PRIME_Z390-A/E15017_PRIME_Z390-A_UM_V2_WEB.pdf?model=PRIME%20Z390-A
Your board doesn't have a 5V ARGB header but it does have 2x 12V RGB headers. FYI, ARGB and RGB are not the same in terms of standards. You could try and see if reverting back to your previous spec helps bring the system back up but you started it with the cable.
Yes, so sorry, Msi z390 - a pro. I tried again with my old ram, and unplugged my new ssd. Cooler is ofc unplugged so both the cpu fan and pump fan header are empty, when I attempted to boot (with basically my old setup) no difference
Nov 2, 2024
56
The CPU is the first component checked during startup. I hoped it was a fan error preventing your system from booting. Is that fan also spinning when you power on?
Yes, it is spinning in sync very shortly when I power on. Don’t know how relevant this is but my front 3 fans are rgb and even tho they spin, they are dark
