afterglow headset firmware corrupt
Nuclearius
120
I have a what I believe it's an afterglow prismatic wireless headset, i was going to update its firmware using the afterglow firmware update utility, the firmware got corrupt and the headset started flashing green and couldn't be used or turned off. On pdp support, they said to let the headset run out of power then update the firmware.It already stopped the flashing but the updater still just says it's corrupt and doesn't update.
is there anyway to fix it? i heard that there is ways to force update but didn't find any
thanks
going to do it now
i think i did what you told me, it was kinda confusing, but the updater still doing the same thing
i don't know if that will work, as to update the firmware i have to plug it on the charger, i think it will see just the USB transmitter, i will still try
