ahhhhh help??!?!?!?!??!?!?! calling starfishy!!!!!
theholylancer
1,948
on the verge of ordering i have noticed that in my mobo manual
( LANPARTY UT nF4 Ultra-D) the ATX power thingy is 24 pins with an extra 4 pin connetor?????????????????? and on my PSU one it looks like <A HREF="http://www.enermax.com.tw/upload/clgcable0217.jpg" target="_new">this</A>????????
will it be compatable or should i get <A HREF="http://www.anitec.ca/?mode=product_detail&pid=3383&mcid=19" target="_new">this</A> ???
help starfishy???<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 02:02 PM.</EM></FONT></P>
Wasn't starfishy helping you with the build?
He has that mobo so he can tell you for sure.
<b><font color=blue>If you try to please everybody, nobody will like you<font color=blue></b>
The Enermax will work with your mobo. The 24pin connector with the detachable 4-pin is to make the cable compatible with 20-pin power connections.
__________________________________________________
<font color=red>You're a boil on the arse of progress - don't make me squeeze you!</font color=red>
easssy boy listen to rugger =Þ
Asus P4P800DX, P4C 2.6ghz@3.25ghz, 2X512 OCZ PC4000 3-4-4-8, MSI 6800Ultra stock, 2X30gig Raid0
oo so i stick the 20 pin connector into the big main slot with 2 pins on either side empty and stick the 4 pin one into the smaller side connector that is suppose to be for the +12 V power??
<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 02:15 PM.</EM></FONT></P>
If the motherboard as a 20 pin connector, youd etach the 4 extar pins and thats it, you then connect the +12v in where it belongs..
If your mobo has 24pin connector than you DONT detach the 4 x-tra pin and thats it!
lost again...... (head titiled)
um <A HREF="http://www.dfi.com.tw/Support/support_us.jsp?PAGE_TYPE=US&PRODUCT_ID=-1&TITLE=&FAQ_HOT_FLAG=FAQ&INDEX_TYPE=MB&SITE=US" target="_new">here</A> is the manual...
can someone goto page 18 and tell me how do i connect the motherboard to the PSU???
in the manual there is a 24 pin connector (i counted)and then becide it is a 4 pin connector that is labeled as +12V power... and in my PSU picture for power there is a 20 pin connector and there is an extra 4 pin power connector... what i do????<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 02:23 PM.</EM></FONT></P>
k im on it =)
thanks man (or women but i wouldn't know 😛)
i'm even sweating here... (although this is more a familiy problem as that when i get nervouse i sweat..... (dad side) i hope i do better whn i ask someone out...)
don;t tell me i need a more expensive PSU.....<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 02:26 PM.</EM></FONT></P>
ok you have 1 24 pin connector and the +12V connector, you have to use both of them.
DOnt split the 24 - pin just plug the long ass connector in it, then plus the other four pin right over it, simple enough no?
that would be man please =)
And uh looking at the pciture of your power supply, lets put numbers on the pics.
3 on top, 5 at the bottom.
so the one on the top in the middle is how you should connect the big connector.
than the one at the bottom left should also be connected right over it...
now i understand.... (smack head)
and now what is the difference between FDC and FDD??? as that my old mobo manual (a soyo SY-6VBA 133) says that the floppy connector is FDC, my new mobo says its FDD (i assumed that its the floppy connector as that its close to them IDE ports...)
<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 02:33 PM.</EM></FONT></P>
I can paint a diagram if you like and mail it to you =)
o ok lol ***************(email addr deleted)*********** i don't want to loose like 90 some dollar over this and most importantly make my dad think that i can;t do anything right..... (he sees my smallest screw ups and not my big successes.... my mom is the reverse though lol... she sees the smallest succcess and not my biggest screw up, sorta balance it out 😛)
<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 02:36 PM.</EM></FONT></P>
Floppy Disk Drive and Floppy Disk Connector/Controller
Something along those line I guess...
And i mailed it =), now dont spam this address its at work =Þ
hehe thanks, and ya wouldn't belive the trouble i went to get that Gmail accoutn and now ppl are giving them away for free (well almost as that ppl here are reciving them for the installiation of F@H)
I got 40 invites or so, had it for a year or so...if someone else wants some ask me...altoguh they shoudl fold!
Talking about that I should start it back heh!
o and BTW when i went and add my panaflo to cart it asked me if i need a 3 pin or 4 pin power adaptor or just bare wire??? what i do? i would think that i would need 3 pin if its just gona be BARE WIRES and i would have to hot wire them to the mobo?
Lol never hear of bare wire...
4-Pin is tobe connected on the PSU 4 pin molex,
3 pin is to be connected on the motheboard. Looking at the layout you have 5 fan connector so I guess you could just plug it on the motherboard.
My Vantex stealth fans cam with a 3 pin connector and a 4 pin adaptor....
