ahhhhh help??!?!?!?!??!?!?! calling starfishy!!!!!
The OCZ you listed earlier is a good option. If it was available, then I would say some OCZ Value VX (model # OCZ4001024WV3DC-K) to save a few dollars - especially with your mobo. For a few dollar more I would take a look at <A HREF="http://www.anitec.ca/?mode=product_detail&pid=2054&mcid=11" target="_new">this</A>. I'm almost certain that it is the Value BH5 memory (read the <A HREF="http://anandtech.com/memory/showdoc.aspx?i=2392" target="_new">Anandtech Value Memory roundup</A>).
__________________________________________________
<font color=red>You're a boil on the arse of progress - don't make me squeeze you!</font color=red>
i try this with me dad first: the extra long SATA cable should be good so that i don;t even need a new case 😛
SKU ITEM QTY UNIT PRICE PRICE
3890 Arctic Cooling 80mm Arctic Fan 3 w/Thermal Sensor 1 $5.95 $5.95
1903 Thermaltake 18" UV SATA Cable (Blue) 1 $15.00 $15.00
3603 OCZ Dual Channel EL Gold VX Series OCZ4001024ELDCGEVX-K w/ Heatspreader (2x 512MB DDR400 Matched Pair, CAS 2-2-2-8@ 3.2V) 1 $219.95 $219.95
737 Seagate Barracuda 7200.7 160GB - 7200RPM, 8MB Cache, SATA150/NCQ (OEM) 1 $125.95 $125.95
3561 AMD Athlon64 3200+ (2.0 GHz) 512k L2 Cache, Socket 939 (Retail) *Venice* 1 $235.95 $235.95
3126 eVGA e-GeForce 6800GT 256MB GDDR3 PCI-Express w/Dual DVI, TV-Out (Retail) 1 $479.95 $479.95
3165 DFI LanParty UT nForce4 Ultra-D, Dual Gigabit LAN, SATA-RAID, Firewire, DDR400 (Socket 939) 1 $169.00 $169.00
3123 Enermax NoiseTaker EG495P-VE SFMA - 485W ATX12V v.2.01 Adjustable Dual-Fan 1 $88.95 $88.95
Subtotal: $1,340.70
Shipping: $29.95
Insurance: $13.00
GST 7%: $96.86
PST 0%: $0.00
Amount Due: $1,480.51
All Prices in Canadian Dollars
should i try to get a SATA cable at my local stor to save some $$?<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/20/05 04:45 PM.</EM></FONT></P>
Thought I had changed the link before I posted. <A HREF="http://www.anitec.ca/?mode=product_detail&pid=2056&mcid=11" target="_new">Here</A> is the right link.
Even <A HREF="http://www.anitec.ca/?mode=product_detail&pid=3253" target="_new">these</A> would work though for a mild OC and would save you some cash. I have used them in a rig that I built, I didn't find anything wrong with them before I turned it over. I never OCed it, but I have heard good things about these sticks... you could give them a try, but the OCZ is a sure thing.
Sure thing is better - especially with a first time OCer.
Save $100 or more on either of these cards:
<A HREF="http://www.anitec.ca/?mode=product_detail&pid=3163&mcid=24" target="_new">Sapphire X800XL</A>
<A HREF="http://www.anitec.ca/?mode=product_detail&pid=3672&mcid=24" target="_new">Sapphire X800 Pro</A>
The X800Pro should OC to X800XT performance levels. The X800XL has comparable stock performance to the 6800GT for $100 less, but the X800XLs usually do not reach as high OCs.
Id go with the VX out of this bucnh.top ocing ram thought
Id suggest Crucial Ballistix, not so expensive and really good. Good OCer too.
Asus P4P800DX, P4C 2.6ghz@3.25ghz, 2X512 OCZ PC4000 3-4-4-8, MSI 6800Ultra stock, 2X30gig Raid0
The issue was the location he was buying from. Both of your recommendations would be at the top of my list, too, but were not carried at that store.
Oh ok..too bad I guess!
i'm gona be calling all my local stores and now after i carefully mesure my distance from the last 3.5 bay to the bottom left edge of my mobo i realized that the SATA wires from the mobo could work 😛 so i just need to be calling around for ram now :) so can someone give me <b>detailed</b> information about the vaulc VX ram like theri ordering number and CAS and all that?
<P ID="edit"><FONT SIZE=-1><EM>Edited by TheHolyLancer on 07/21/05 11:39 AM.</EM></FONT></P>
<A HREF="http://www.anandtech.com/memory/showdoc.aspx?i=2392&p=8" target="_new">Click@!</A>
Rated at 2.5-3-3-7@200mhz but anand made them run at 245mhz 2-2-2-6!
And from <A HREF="http://www.xtremesystems.org/forums/showthread.php?t=59957&page=1" target="_new">Here</A>
7. OCZ Value VX (VX but unbinned by OCZ NOW USES BH-5 UTT)
How to identify : OCZ400512WV3 *must have W there*
How to identify whether it's BH or CH? here
Where to buy : Newegg , Atacom
Readings and user's results : Anandtech , Xtremesystems
Price : USD114.95 at Atacom 1GB Kit
OCZ Value VX = model# OCZ4001024WV3DC-K
