AIDA64 EXTREME - Mouse stuttering
dhamiltongrey
117
Hi,
Im doing a stability test using AIDA64 EXTREME - bought the licence and brilliant program, however when i run a stability test i get 100% cpu usage and a jittery mouse.. sometimes the mouse freezes..
any ideas whats causing it?
The test, it's designed to use as much cpu usage as possible which explains the cpu usage, also the mouse problem is caused by your cpu using everything on the test
