Question Aio Cm 690 II Advanced
Is this the case you're working with?
https://coolermaster.egnyte.com/dl/ALw4m3HktP
States you can have a 240mm at the bottom but that is not advised for an AIO as the air will find it's way tot he highest point in the loop/build meaning the pump/CPU cooling block, i.e, your AIO will fail prematurely.
best stick to air cooling or pick up a new case with provision/mounting option(s) for a 240mm AIO.
What are you trying to cool? If the concurrent generation of processors, you should look into a 360mm AIO.
Also the thermal
Thanks for your reply I will be cooling a ryzen 5 5600.
This video states there is room for a 240 to 260mm radiator at top and also on the bottom
View: https://www.youtube.com/watch?v=rYocr0EWpMw
Also in this specific aio has the pump on the tubes not in the block so it can be in the bottom
Can u please reply
