Greetings,
So this is my first build in years, I'm using Thermaltake view 71 case,
Heres my current setup :
3 front fans as intakes.
3 top fans as intakes.
Mid mounted AiO " Right behind the front fans " exhaust to the side.
Back fan as exhaust.
I've seen a couple of videos on youtube conning the mounting of AiO with the tube on the top, but mine does not reach if i mount the tube on the bottom.
Heres my question/s :
How should i setup the optimal airflow for my case?
Is there too many intakes with little exhausts?
Should i mount the AiO on the top? if so should it be intakes or exhaust? also what of the top mounted fans? do i mount them in the middle? as intakes?
Also should i add an intake/exhaust fan at the bottom?
Here's a photo of my setup; Photo
Thanks in advance,
Thanks in advance,
