Hello I just purchased the NZXT Kraken x52’s and I am swapping out the fans because the thickness of the stock fans won’t fit past my ram sticks, I purchased other fans that will fit but what I’m wondering is Can i swap the stock fans out for my rgb ones I just purchased and keep my rgb ones connected to the controller because they wont fit into the AIO? The cords on them arent 3 pin or 4 pin they just have the controller connector, I know I won’t be able to use CAM software to control the fans, but I can control fan speed with the controller remote.
