Question AIO In case on top Question
Feb 7, 2015
13
Guys hello, I'm interested in the following information:
I have the following PC
I am going to purchase ARCTIC Liquid Freezer II 240 ACFRE00046A my question is , will it fit on top of the Case? as I am aware radiator is way to thick on this particular AIO, will it interfere with the Motherboard? space wise?
It supports it on the top.
But that ram seems to be very tall.
So there may be some interference with the ram and the AIO, but you can mount it on the front without any problems.
Plus the front panel has mesh so there will be even more airflow.
Feb 7, 2015
13
So atm my case has 3 Fans in front, I just need to remove 2 of them and replace it with the AIO radiator right? and it should act as an intake ?
