AIO Liquid Cooling Problems - Triton 360
Subressor
95
Hi all,
I have recently purchased a Triton 360 (AIO 360mm Liquid CPU Cooler) and love it! I just wanted to ask 2 questions though and Rajintek's website isn't letting me send emails...
1) When I received my Triton 360, I could see a gray residue within the liquid, in the hose and the pump block. Not much, but if you shake it then its like a snowglobe. Is this normal? Or could this be a problem?
2) I am having a little trouble installing the block so that the hose does not kink, it is VERY flexible! Maybe too flexible... I have tried all different angles but I cannot get it to not-kink (I have a PC-O8 case). What can you recommend to alleviate this?
Thanks!
some tubing uses plasticizer in them and it can leach out and get clogged in the cpu block
though dont know if the tubing in that one does or not
anti--kink coils you get for whatever diameter of tube you have--they also come in different colours so can get a colour to match your build
It's uncoloured... what's plasticizer?
Thanks, I'll try and find some coils - any you recommend for this AIO?
Thanks! The packaging says the Trition 360 hose has OD (outside diameter) of 12.5mm... Will a 1/2" anti kink coil like this fit & work?
https://www.ekwb.com/shop/anti-kink-coil-12-7-mm-1-2-uv-red-pcc-12-ur
It's 0.2mm out, but will that make a difference?
Not sure on the tubing problem... It has a cap you can take off to refil the liquid so I guess I CAN replace it before I install it, but it may void my warranty. What are your thoughts? Does this indication give any rise to the catastrophic chance of a leak?
Hi @mcnumpty23,
Just wanted to give you an update now that I've successfully built my PC using a Triton 360. The Anti-kink coils worked a charm! the Triton needed 1/2" coils, which isn't standard apparently... and they are a pain to put on, but they give it more than enough strength, and I think my setup is one of the worst for tubes.
Thanks again!!
