Question AIO not working after cleaning PC ?
Oct 12, 2022
5
I decided to clean my pc i did use a air compresser knowing that is wasnt the best idea but i kept a good distance so i dont think that its the problem. After i was done cleaning i booted the pc up and it was almost instant on 90C* i quickly turned it off, i tried to look at what was wrong and i found out that sometimes if i moved around with the caples it would have normal tempreture this happend 2-3 times but it would after a couple of minutes get back up to 90 C* again
BTW the led is working.
PLS HELP
Did you disassemble your entire build or did you simply blow air with the compressor? Also, where are you located? Some regions are advised not to use air compressors. Lastly, can you please pass on the specs to your build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
You might want to check and recheck all connections from your PSU to all your components. You can likewise try and breadboard the innards to try and see if the system can be revived.
Reactions: M4knus
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
Thank u:)
no i didnt disassemble only took all the caples out and moved it out so it wasnt a complete cleaning just the dust, i live in Denmark
CPU: i7 10700k
Motherboard: TUF GAMING Z490-PLUS (WIFI)
Ram: G.SKILL Trident Z Neo 4 x 8 GB 3600 c18
SSD/HHD: SSD M.2 1TB Samsung 980 NVMe PCIe and a 2 tb hdd
GPU: geforce 3060
PSU: CORSAIR RMx Series RM850x
Chassis: Cepter carapace cube
What is the make/model of your aio?
How is it connected?
Don't you hate it when you try to do something simple and end up with a problem worse than what what you fixed 🙁
In the case of the cooler, double check that the pump has not been dislodged during the process.
Look to see that the pump is working and that the radiator fans are working.
Note to Lufij: You might amend your list of specs to include the cpu cooler.
The OP clearly went top to bottom and included what you asked.
And no more.
Don't you hate it when you try to do something simple and end up with a problem worse than what what you fixed :)
And no more.
its either the kraken x63 or x53
its connected as it should everything is connected where it is suposed to
the fans are working and the radiator is very cold even when it has been running for minutes
but nzxy program says its 95C* and my motherboard has a red light
What does your motherboard manual say that the red light means?
I might guess that your cpu fan header or cpu pump header is not properly connected.
i think its becouse of the cpu heat becouse its only on when it above 90C*
Do u think i might just need some new cooler paste on my cpu?
