Question AIO pump settings?
Soj1337
14
Hi I've got a MSI 240r installed in my CPU and I was looking thru bios & MSI fan control in the center. I can't figure out what the best settings are,
By default it just says auto, I've been told I should set to pwm and have smart fan curve at 80% to 100%. Same speeds
Also shall I just let MSI center sort out all my other case fans by using auto fan tune.
Thank you :)
Yes, let your system optimize all the fans at first using the Fan Tune option. THEN check the CPU_FAN header where the AIO system is plugged in and make sure of these two settings:
(a) Set Mode to PWM Mode, not to DC nor Auto.
(b) Set to Automatic or Standard Profile; do not use a fixed fan speed.
This will ensure that the PUMP unit gets full power at all times as it needs, and that the rad FANS will be controlled automatically according to actual temperature inside the CPU chip.
