Hi, a few days ago i bought a new PC and everything seemed to work well but yesterday evening my pump began to make this buzzing sound. Reddit posts that i googled and chat gpt suggested to try tilting the PC but it didn't help. When PC is upside down pump makes like a gurgling sound and sometimes it is fine for a moment but then i bring it to the original position and it is there all over again. Pump runs at full power and from what i gathered in this model it cannot even be changed. It works fine too, I manually changed the fan curve and even then in idle CPU is below 40 degrees celsius, in stress while gaming temperatures are great too, heavy stress means around 70 degrees.
So everything seems to be working well except for that sound that drills into my skull XD For a few hours first when the issue began the buzzing would stop for a few seconds once in a while but it seems that now it just buzzes all the time... Do you maybe know whats going on and have any advice?
Thank you, I will really appreciate your help <3
Here is my complete setup:
Deepcool LS720S Zero Dark 3x120mm - AIO
Gigabyte B850 GAMING X WIFI6E
MSI MPG GS 850W 80 Puls Gold ATX 3.1
AMD Ryzen 7 7800X3D
Zotac Gaming GeForce RTX 5080 SOLID CORE OC
RAM Kingston FURY Beast DDR5 32GB (2 x 16GB) 6000 CL30
msi mag pano 100r pz
