sethwheeler01 :
vasodavitaia :
Your motherboard has only 1 RGB Header to plug, so you'll need a splitter to connect those 2 fans and pump RGB, and that 1-to-3 splitter is included with your AIO cooler.
Yeah I figured that much. But everything will be recognized on AuraSync and powered properly through the splitter?
AuraSync is for ASUS motherboards, in my opinion best RGB soft among all other manufacturers softwares, but as long you have 1 RGB header and Chipset heatsink with lights, connected 3 fans and Chipset will be synced. Asrock RGB software is worst in my practice and you will not have that much effects and sync modes compared to ASUS for example.
Short answer to your question: yeas, it will technically run with no problems and it will look awesome.
