I am buying the Air 740 soon, and I already have bought my components and I know that they're compatible with the case. I am willing to pay for some new fans and I would like to get some recommendations on CPU cooling.
My current build is
-Asus Z270E
-GTX 1070 Strix
-H100i V2
-i5 7600k (Which runs quite hot)
-EVGA 650w G3
-Ripjaws 3200mhz 8x2gb
My plan was to buy 3 120mm fans as a front intake. (Give me recommendations on what fans to use) And use the two included AF140's as a bottom intake. I would then have the one included fan on exhaust. Would this cause too much turbulance? And my h100i V2 has really disappointed me, so should I use only two of the front intakes on the rad and then have fans on the bottom to feed the GPU instead? Or could I fit a 3rd fan underneath the radiator? And is there a way I could keep my temps cool without having a jet engine in my room?
My current build is
-Asus Z270E
-GTX 1070 Strix
-H100i V2
-EVGA 650w G3
