Quick question. I'm installing an NZXT Havik 140 air cooler onto an Asrock Z68 Fatal1ty Professional mobo. This cooler is a metal heatsink with a 140mm fan on either side.
If I mount the cooler where the fans are blowing across the cooler front to back, the preferred method and the only way I've seen it installed, I can't quite center the heatsink over the CPU, although the heatsink will fully cover the CPU, and the front fan is right up against my first stick of RAM. It fits, but it is just touching that first stick.
If I rotate the cooler 90 degrees where the fans are blowing across the heatsink from bottom to top, there is plenty of clearance between the fans / heatsink and my RAM, and I can center the heatsink on the CPU.
This is an AZZA Hurrican 2000 case, so there are 2 fans in the top of the case carrying air out.
Which way is better for this scenario? Front to back, or Bottom to top?
Tx
Tx
