Hello, all!
I am currently using a Corsair Carbide Air 540 because I want to stick with air cooling over liquid, I love the cable management, and I think it just looks great.
Presently, I am running a 2 way SLI setup of 4GB GTX 770 FTWs and I'm looking to move to 3-way SLI with the same cards. I purchased a Cooler Master Hyper 212 EVO as well because I plan on OCing my processor to try and keep up.
What I'm wondering is:
1.)Are the stock case fans on the Corsair Air 540 good enough? If not, what are upgrade options that will have a significant impact on the temperatures?
2.) Should I get a new 120MM fan for the Hyper 212 EVO?
2.) What ratio of input to exhaust fans should I put on the case? Aside from the stock fans, I have a single Cooler Master R4-S4S-10AK-GP fan mounted near the back to form 2 front input : 1 top and 1 rear exhaust.
Green colored LEDs might be nice if I can somehow get SHODAN etched into the side pane, but I'm fine even with colorless!
Thank you for reading my post, and I would appreciate any input.
