Air cooling hack
JoeMomma
860
I have a Geforce GTX470.
It is a great card but it runs hot and loud.
When the squirrel fan gets to 80%, it sounds as loud as a jet engine.
The first thing I noticed was that the card was sucking in hot air coming through my hard drives.
I made an L-shaped baffle from a plastic rectangular juice jug.
I cut off two sides of the jug and placed the baffle in the 2" gap between the drive bay and the cards.
Hot air from the drives is directed behind the geforce to the RAM and CPU side of the motherboard.
The cards are supplied with fresh air from the 135mm fan on the case door.
To increase airflow through the geforce, add a 76mm/3" fan to the heatsink cap.
Remove the geforce cap/duct that is over the heatsink.
Drill four holes in the cap to attach the fan right over the opening to the 50mm/2" squirrel fan.
Attach the 3" fan to the cap w/ screws and power it up.
The additional 3" fan blows more air through the geforce and lowers temps a lot.
I see about 10 deg C lower in Windows and 5C lower under load.
This hack should work for just about any graphic card that runs too hot.
Not that I have issues at all, as I have a case where the air flow goes directly into the case and across the graphics cards and the CPU, which made my 470's run much cooler and quiet over my previous Antec 102 case, but I'd love to see pictures of this setup.
Still wouldn't work for my case lol, 3 gtx 470's, 2 sound cards, 5 hard drives and 2 bluray drives kinda kill any airflow i couldve had even with a storm sniper with 3 220mm fans.
Here is the inside of my case as requested
Custom Iridescent BLACK
' Lewis Hamilton Formula 1 mid-tower case
OCZ 700 Watt power supply
APC Battery BackUPS-ES750 10 outlets
Intel Core 2 Duo E8400 - 3.4 Ghz
EVGA nForce 750i FTW motherboard
EVGA GeForce GTX 470 video card
Acer 24” LCD monitor
8 GB 1000 MHz Kingston Hyper-X RAM
HighPoint RocketRaid 640 SATA III PCIe card
120 GB Patriot Pyro Solid State Drive
500 GB Seagate Barracuda hard drive
2 TB Western Digital Green hard drive
Thermaltake e-SATA backup dock
' w/ 3 Western Digital drives
Lightscribe DVD-RW + CD-RW drive
CD-ROM drive
HP 6988 Photo printer
Epson Perfection 2400 scanner
Haupauge WinTV PCI card
Hidden BLUE interior LED fans
' 2x 120mm case, 92mm CPU, 135mm door, 75mm GPU
' Custom GPU Intake Manifold and fan
Windows 7.1 Professional 64 bit
WACOM Large Bamboo graphics tablet and pen
Microsoft Wireless keyboard 3000
Microsoft Wireless mouse 5000
MadCatz Cyborg R.A.T. mouse 3
MadCatz Xbox controller
Logitech MOMO Driving Force steering wheel and pedals
Logitech Attack 3 joystick
Logitech G5.1 speakers
Benchmark Test Results
PassMark perfomance test v6.1 x64 = 1735
http://www.passmark.com/
3D Mark11 Entry level = 3889 Performance level = 2710
http://www.futuremark.com/
The cables are deliberately placed to block all beneficial airflow.
Ha! Gotcha didn't I.
Troll.
My small case is packed to the max with components.
In this photo one cannot see the HD fan, the CPU snorkle and the big side fan.
Please notice there are no cables in the way of the Geforce intake.
I have plenty of air flow where I need it.
My over clocked CPU and my HD's have never had a heat problem.
Yes, I have a cheap $50 case and an older Core 2 CPU.
It is easy to solve problems when one has unlimited funds.
I prefer to experiment and apply my engineering skills to maximize the efficiency of an existing system.
I test, I tweak and then I test again to see if my experiment worked.
Not all of them do.
And it still works great and kicks butt.
I can play any game at 1920x1200 with full detail and get over 60FPS.
I want a new Core i5 and DDR3, but I don't need it yet.
My case is just big enough to fit a full size mb and all of my stuff inside.
I do not have a modular PSU right now, so there are a lot of extra cables.
The other thing one can not see is that my case is on its side, and a larger case would not fit on my desk.
Because of it being on its side conventional airflow management does not have the benefit of convection.
I have exercised cable and airflow management, it is just that you can't see all that I have done from one photo.
I endlessly experimenting with improving what I have.
I am not so anal that I worry about managing every cable inside of a box that no one will ever see.
The extra cables I just stuff in wherever they will not block critical components.
The cables are always getting moved about, so I placed them on top near the drives and the airflow is directed underneath.
Where the heat, the motherboard and the memory is.
I am so sorry every time I post on this Forum.
Too many trolls.
I forgot that I swore to never try help anybody ever again.
I'm sorry, I didn't think I was trolling, but I would have liked another picture or 2 from other angles. That one makes it tough to see the mod you did. I don't fully understand where the air is coming from from that angle and it might even be magnifying the cable management issue.
As far as the case goes, this one is cheaper than you might expect. I believe I payed $120 for it. I also place on the ground next to my system, rather on my desk, except if I'm working on it at the time. Having good cable management and a good case makes adding things a lot easier. I used to cringe every time I'd add things before I managed my cables.
I like a simple small case.
I keep it off of the ground because it gets too dirty on the floor.
The main thing missing in the photo is that there is a large 135mm side fan blowing in directly over the GPU and mb.
That fresh air gets sucked into the geforce and the hot air from the drives in front is directed out the back.
Just because you see cables, that does not mean they are in the way.
I AM DONE!
the responses by the people in this particular thread are not that 'troll' like. I would like to see the mod from a better angle.
Your cable management doesn't look good, but if you have come to the conclusion that the cables are not restricting airflow in a negative manner then it is irrelevant.
on the subject of swearing to never help anybody ever again. That is simply an unfortunate but semi-understandable mentality.
Thanks snappy, I tried that but it would not fit.
So I decided to block the airflow between the HD and the GPU and let the big fan blow everywhere.
Half of the big fan is over the cards and half is over the mb chipset fan.
One other feature of my case is the side has a telescoping 3" fresh air intake tube for the CPU heatsink.
For that reason I selected a high quality downdraft heatsink that floats over the CPU on heat pipes.
Every slot on my mb is occupied, but I ran the cables in the card area under the last card.
Just look at all of the devices I have listed that are in my little case.
I have edited the photo I took today, and here is an older pic that shows the airflow better.
When I added the SSD, the airflow in the old pic was blowing hot air into the GPU and the temps went up.
I like to help people, but the users on this Forum are so much smarter than I am that they don't need my help.
And they are mean and call me stupid.
Like, I only have a Masters Degree in Mechanical Engineering and have been building computers since the 1980's, so what do I know.
This was intended to be a simple note about a simple hack.
Maybe I am just to old for this crowd.
not knocking you or anything but do you really need all that *** in there i understand redundancy but the amount of drives u have is ridiculous maybe u should consider nas backup or something like that because with a case crammed like that everything must get pretty toasty
NAS Backup = $1500 w/ drives, yeah right.
Why would I need a NAS for a $1000 home PC?
I have a SSD, a fast Barracuda for other software and a 2TB WD green for everything else. I have two dvd drives. I have tried to remove the floppy, but I got a error even though I disabled the floppy in BIOS, so I left it in.
As for cards, I have a TV tuner card (I don't own a TV anymore), I have a sata 3 RAID card for the SSD and also it is much faster than the nvidia mb sata 2 with my older drives. My geforce takes up 2 slots and I have an EVGA power boost pcie card that feeds the pci bus more power. All of my backup needs are served by my esata dock and multiple drives.
Why must you continue to criticize other peoples setup.
I did not build an Xbox, this is a general purpose engineering and graphics PC, that just happens to be a kick butt gaming rig as well.
While I think you have a nice PC, please remember the computers are meant to be general purpose machines. And I have other things to spend massive amounts of money on, like my house, my car, etc. Most of the time good enough is just fine. One does not need a 200 mph Porsche to drive to the market, when my 150 mph Subaru WRX will do just fine.
Jeez, all I did was screw in a little fan and I am having to justify myself to people who just don't understand that PC's are as different as the people that own them.
BTW: To quantify.
Is 40C on the CPU and 45C on the GPU too hot or just right.
Under load the CPU goes up to 55C and the GPU gets up to 80C.
The geforce is safe up to 104C and was running loud at about 90C before my hack.
I also adjusted the fan curve in MSI Afterburner so that it never has to run faster than 80% rpm.
The temperature was never a problem, it was the noise of the geforce fan that I fixed.
For a 470, that's pretty good if you ask me. 470's are known to be hot.
