ct1615 :
i totally agree with your second part but who here changes their cases yearly???
I've seen a few go through them here, but I mostly meant boards like these. This one tends to be a little less about the enthusiast and a little more about helping and discussion. Go over to OCN, TPUF, or XSystems and you'll see what I mean (though on OCN, they mostly go through $300+ cases yearly...).
anroin :
I'm using a ATX mobo,but further compatibility would be good.I also have one hard drive.Actually it's a pretty "standart" system with no OC,no SLI.My new motherboard (P7P55DE-Deluxe) and its shield didn't fit in the case properly for some reason,so I thought I'd get a new case for this build.Otherwise I'd get a 30$ case and pile in the leftovers XP
Which cases from Lian Li would you recommend than?
Haha, Lian Li might be a bit rich for your blood. Their quality cases with good cooling start off at the PC-P50:
-Windowless
http://www.sundialmicro.com/lianli_mid-tower-pc-case-pcp50b_1927_1616.html
-Window
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=103_104&products_id=27159
After that, your looking at the ~$250 range or more. These are very good:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=103_104&products_id=23304
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pc-v1020&x=0&y=0 (The Red is my favorite looking case out. The Red color is far darker in person than in the pictures)
Now if your willing to go that high, then I say good for you, because Lian Li is the absolute best in quality. But since your likely not feeling that rich, I recommend sticking with Silverstone, unless you are.
anroin :
Also,I just noticed the Silverstone has the outputs for GPU etc. on TOP of it?
Yep. The Silverstone RV02/FT02 have three massive 180mm fans on the bottom, which forces very cool air into the case and forces, with the help of the principal that heat rises, the hot air out of the top of the case. This will give you great cooling all around, and external exhaust GPUs, especially ones that run hot, will absolutely love it. These cases are some of the best cooling cases on the market, especially with multiple GPUs and Fermi GPUs. They are also dead silent, great quality, and extremely easy to build in, even if it doesn't look like it. I can't recommend these cases enough.
