[SOLVED] Airflow in pc case
obi1kenobi
Great
Jan 13, 2019
155
Hi all I’m installing a 280mm aio in the front of the case,2 fans on top and 1 in the rear. What setup should I use which is optimal. I have the Corsair spec 6. I was thinking of pushing from the aio and pushing from the top and just pulling out air out the rear is that a good setup?
Previously I had 2 140mm in front which were pull And the rear and 1 top fan were pulling with an empty slot available which was in my Phanteks case
Hey obi!
To be honest as long as your mount your aio in the top or in the front its all good.
You are not going to get a significant overclock difference.
So yes its a good setup:)
