Hello, I am trying to fix up Dell Alienware 15 R3 for a friend. He complained about his battery being completely dead so that his laptop needs to be constantly plugged in and that his fans were broken and won’t turn on, leading to the laptop overheating sometimes and switching off. I bought a (non-original) replacement battery (though from a reputable spare battery website) and replaced his battery. Upon switching the laptop on, I noticed the fans ramp up and stop, as how some devices test their fans on bootup, so I confirmed my suspicion that the fans are actually OK and it must be some power management thing.
After changing the battery an Alienware Support Assistant message started coming up every time the laptop is switched on saying “The battery cannot be identified. The system will be unable to charge this battery”. I do not believe this was appearing with the original battery, even when dead, but I might be wrong on this. It would also sometimes show “255% battery available” in Windows, which I can only assume is an integer overflow. Thinking it’s surely error on my part, I took it apart again and reseated the battery connector and made sure it’s connected well, but that didn’t make a change. The seller said that the battery “might not be calibrated”, so I should update the BIOS and leave it on charge for a few hours, but it could also mean that the laptop does not accept third party batteries.
As for the overheating issue, I immediately noticed upon switching it on, that the laptop is running very slowly. For some reason it is stuck in a low battery/overheating profile and the CPU is permanently throttling at 0.71 Ghz. I tried to mess with the power profiles, delete some old utilities he had installed that might mess with it, but nothing changed. Despite the CPU running at around 50-60C (even on 710 Mhz… had not yet repasted it at this point), after a few minutes of usage it would shut itself off due to overheating, so I turned on Fan Turbo Mode in the BIOS, so at least I can fix this without the laptop constantly shutting down. After reading online about this, it seems a lot of users have similar issues on laptops with 6th-8th gen Intel CPUs and it’s caused by a Windows 10 update. They recommend updating the BIOS as that apparently contains microcode that alters the CPU behaviour, so that the bug within Windows is fixed. Seeing that it was now two places that recommended a BIOS update, I went on Dell’s website and downloaded the latest version to replace the installed version 1.6. However, as I ran the installed, I got the message that "your battery needs to be at least 10% charged in order to install this update"… I tried running it in Safe Mode, it didn’t work… So now I am out of ideas. I don’t know how to go around that battery check and update the BIOS – don’t know if it’s even possible… And I have the fear that either the battery cable or the motherboard circuitry for the battery have gone and no battery will work, no matter what battery I buy and how many times I change it. I guess the message saying “the battery cannot be identified” probably means that it is at least picking it up. It’s a shame, because other than those things the machine works really well, he is used to him and it still does the job very well!
Has someone faced any of these issues before? Help!
