I wish to water cool a AMD FX 8300 and overclock it a bit.
I compiled this list of parts.
CPU block:
https://www.aliexpress.com/item/32918709647.html?spm=a2g0o.cart.0.0.4f733c000Xzk4k
Radiator:
https://www.aliexpress.com/item/32908657121.html?spm=a2g0o.cart.0.0.4f733c000Xzk4k
Pump,res. combo:
https://www.aliexpress.com/item/32917040373.html?spm=a2g0o.cart.0.0.4f733c000Xzk4k
Tubing:
https://www.aliexpress.com/item/32839748359.html?spm=a2g0o.cart.0.0.4f733c000Xzk4k
I know there are better and less expensive ways to do cpu cooling but i wish to try something new.
I currently have the stock AMD cooler that isn't cooling the FX 8300 nearly enough.
Any suggestions?
Any problems withe the part compatibility?
Any better aliexpress water cooling parts?
CPU block:
Radiator:
Pump,res. combo:
Tubing:
Any suggestions?
