So I built a rig of spare/donated parts I had laying around for a buddy of mine who has no consoles or computer at all.
The issue is that all of the fans in the pc (including the power supply fan) constantly run at max speed no matter what I do. I've tried adjusting the bios settings but regardless of which options I choose the fans have no change. I've reset the cmos, I tried flashing the bios to the uefi interface but it fails. The Temps are all really low, everything was cleaned and repasted with Kryonaut thermal grizzly to make sure heat wasn't the issue but all stats point to low Temps.
The Cpu fan is a 120mm 4 pin pwm, the exhaust is a brand new 80mm 3 pin and the intake is a 120mm 4pin and they are all plugged into the board to their corresponding header.
here are the specs :
I5 2600 w/hyper 212 cooler
ECS P67h2-a3 mobo
12gb gskill 1600mhz ddr3
R9 280
128gb SanDisk ssd
1tb wd black hdd
600w OCZ psu
The computer runs perfectly normal other than the fans at 100% constantly. Thoughts plz?
ECS P67h2-a3 mobo
R9 280
128gb SanDisk ssd
1tb wd black hdd
600w OCZ psu
