Primary use: Some gaming, multi-tasking, web browsing, low profile video/sound edition.
Budget for this parts less than 900 (dont need Case, CD, keyboard or mouse)
UPDATE SEE BELOW
CPU: AMD Phenom II X4 940 190 I dont plan to OC to much, so the Stock fan should be good?
Memory:
1. G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166 for 55 USD
2. OCZ 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) http://www.newegg.com/Product/Product.aspx?Item=N82E16820227362 37 USD with the combo offer
Worth paying the extra for the gskill kit?
HD Western Digital Caviar SE WD3200AAJS 320GB for 50 USD I dont really need more
VGA:
Many options here
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161269
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161265
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161247
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102831
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102826
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801 this one have a discount with the phenom 940
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102830 this one have a discount with the phenom 940
I really care for price, and I dont really know if the extra mhz in the core will be that big difference.
MOBO:
my primary option was:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138130 discount with the phenom 940
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138137 discount with the phenom 940
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131384 discount with the phenom 940
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
Discount for the 940
Monitor: ASUS VH236H Black 23" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail 200 USD
Best option for the price?? Want the size and the HD
PSU: Dont plan is using crossfire right now, so just the power for 1 HDD 1 GPU, the CPU and thats it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341012
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
UPDATE SEE BELOW
Memory:
VGA:
Many options here
MOBO:
