I've got the Gigabyte GA-MA790X-UD4P mobo, which supports AM2/AM2+/AM3 CPUs. I am looking at purchasing a better cooler, specifically the Gigabyte G-Power II Pro (http://www.newegg.com/Product/Product.aspx?Item=N82E16835128022). It lists compatibility with the AM2 chipset, but I am curious as to whether it will work with my Phenom II X4 955BE. Since the specs on the AM2 and AM3 processors are just a little different, I'm concerned that the G-Power II Pro may not perform correctly with my CPU.
Since my mobo supports multiple processor types, and it's built to fit coolers for multiple processor types, I'm under the assumption that any cooler that's made for a AM2 or AM2+ will fit properly on top of an AM3. Performance issues aside, am I incorrect in assuming that I can take any cooler made for a AM2/AM2+ and put it on an AM3?
Since I pretty much mangled my stock cooler (don't ask 😗 ), and none of the stores in my area carry anything but Thermaltake crap, I'm getting desperate for a compatible cooler for my system. I think the Gigabyte cooler may fit the bill, plus it looks wicked cool. I've already emailed Gigabyte regarding this issue, but no response from them so far...
Any ideas, oh ye Gods of Hardware?
