My cooling brackets on my am4 motherboard don’t actually feel like they will stay in place after or while mounting cooler. Just in case you’re wondering, I’m using masterliquid ml240l rgb cooling
yeah i have those exact brackets, but they dont stay in the mobo, so if i try to mount to cooler itself it wont stay on, and very easily pulls them out, so the cooler doesn't stay on the cpu and cant cool it.
Ah, I think I can see where the problem is. Depending on which Ryzen it is, it's cooler may be the one that screw directly to MB thru those 4 holes. like with R5 1400 processor. Others use those plastic parts to hook the cooler same way as with FX processors and before.
