AMD 8350 and GTX 970, help me pick a motherboard please?
Mattl12
6
AMD 8350 and GTX 970, which motherboard should I get? Intend to do SLI eventually and want to stay in the $100 USD range if possible
Spend a little more and go with the newer 990 chipset , ready for DUAL cards.
990FX Extreme6
Mid ranged 990FX motherboard with support for 220W CPUs
http://www.asrock.com/mb/amd/990fx%20extreme6/
Motherboard: ASRock 990FX Extreme6 ATX AM3+ Motherboard ($146.87 @ Newegg)
Total: $146.87
Generated by PCPartPicker 2015-01-07 15:24 EST-0500
Supports Socket AM3+ / AM3 processors
Supports 8-Core CPUs
Supports 220W AMD FX-9590 & FX-9370 CPUs
Nichicon...
I would go MSI 970 GAMING ,support SLI , good quality and nice value.
Motherboard tier list: 970 chipset
Tier One-Class A: Very High quality. Great boards for OCing, have optional SLI capability but more importantly can OC FX 8 well, if you have to get a 970 chipset board, these will be your top choice. High quality, and no overheating issues.
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard ($99.89 @ Newegg)
Total: $99.89
Generated by PCPartPicker 2015-01-07 21:00 EST-0500
get a nice gaming rig:)
990FX Extreme6
Total: $146.87
Nichicon 12K Platinum Caps, Digi Power, 8 + 2 Power Phase Design
Supports Dual Channel DDR3 2450(OC)
3 PCIe 2.0 x16, 2 PCIe 2.0 x1
Supports AMD 3-Way CrossFireX™, NVIDIA® Quad SLI
7.1 CH HD Audio with Content Protection (Realtek ALC1150 Audio Codec), Supports Purity Sound™ 2 & DTS Connect
Qualcomm® Atheros® Gigabit LAN
5 SATA3 . 1 M.2 (PCIe Gen2 x2 & SATA3) . 1 eSATA3
7 USB 3.0 (2 Front, 4 Rear, 1 Vertical Type A) . 10 USB 2.0 (4 Front, 6 Rear)
Supports ASRock Cloud, Full Spike Protection, X-Boost
ADD some Ripjaws Modules.
