T turtlesforlifee Reputable Mar 11, 2014 11 0 4,510 May 6, 2014 #1 hi i have an amd a4-4000 apu that i want to over clock. i dont know whta a safe speed would be. btw im using the stock heatsink it came with
Solution hang-the-9 May 6, 2014 It varies CPU to CPU. 10% should be safe even on stock cooling. Read though this to make sure you do things right http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/amd_fm2_overclock.html
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 May 6, 2014 Solution #2 It varies CPU to CPU. 10% should be safe even on stock cooling. Read though this to make sure you do things right http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/amd_fm2_overclock.html Upvote 0 Downvote Solution
