P phtttttt Commendable May 26, 2016 5 0 1,510 May 26, 2016 #1 Will a gigabyte ga-f2a68hm-ds2h motherboard support a athlon x4 860k. The motherboard manual keeps talking about an apu.
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 May 26, 2016 #2 Athlon X4 860K is a CPU with no processor graphics. A video card is required when using it. AMD also makes the A-Series APU's with processor graphics. http://www.amd.com/en-us/products/processors/desktop/a-series-apu CPU Support List: http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=5260 If you look in the List in the GPU Frequency column you'll see N/A for the Athlon X4 860K as it has no graphics. Upvote 0 Downvote
P phtttttt Commendable May 26, 2016 5 0 1,510 May 26, 2016 #3 Yeah and I am buying a GPU but the motherboard manual always says apu not cpu. Will this cpu and the r9 380 work on this motherboard? Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 May 26, 2016 #4 A video card is required when using it. The R9 380 is a video card. Upvote 0 Downvote
P phtttttt Commendable May 26, 2016 5 0 1,510 May 26, 2016 #5 Yes, but the motherboard manual never says anything about a cpu. Only an apu. So do I need to do anything special besides the GPU and drivers? Upvote 0 Downvote
