My AMD Athlon 64 3000+ Socket 939 hangs around 40-50's but has hit the high 50's and low low 60's before. this seems high to me, what is considered dangerously high??
Thanks,
Michael
Ortega Associates
What is your cooling? If you are using the Stock HSF (Heatsink/Fan) and it is a newer 3000+, that is pretty high. Your temps should be about 30c idle and 40c load, give or take. It also depends on the environment, if your room temperature is over 80f, your CPU will idle about 40ish and load about 50ish, give or take again. My best recommendation is to upp the cooling in your system, blow all the dust out (I can't begin to explain the amount of systems I've lost and had to rebuild for people because dust caused overheating of systems/servers) and reduce room temps if needed.
"Dangerously High", for me, would be over 65c. Some people (especially Wusy, no offence) will say even 85c for prolonged time is okay, but I severely disagree. I've seen hundreds of systems die due to heat because of even 50c-60c temperatures, but it depends on the system.
SideNote: Your website says you're in San Diego, I was born there, how's it there now? I haven't been out there since I was 2 years old, but I've always wondered how it's been there....
~~Mad Mod Mike, pimpin' the world 1 rig at a time
