CPU : AMD AMD Athlon 64 X2 4000+
Motherboard : Asus M2V MX SE
RAM : 2+1 GB DDR2
HDD : 160 GB Seagate
PSU : Hytech 400W-P4
Hi Team,
I have installed Windows 10 on the above Desktop config. Windows is working slow but is manageable. The issue is the temperate is around 100 degrees C from the time is start the desktop and load is around 100% on both. On mild use it doesn't get switch off. On even slightly heavy use it is getting off all of a sudden. I have tried cleaning the heat sink with vaccum cleaner and there is one addtional fan. The top cover is kept open to let the heat out. Can experts please help what should I do?
I also want to increase the RAM on this desktop. Can you please suggest which one should I buy and what is the maximum GB RAM I can go?
RAM : 2+1 GB DDR2
Hi Team,
