AMD eyefinity on diffrent resolution problems
Dec 10, 2014
6
Okay first things first i know my monitor resolutions are terrible butt i have:
2x 1440x900 -20inch
1x1600x900 -19inch
I ran a Nvidia based PC for awhile (GTX 660) and recently bought the AMD 7970 (Asus direct cuii)
On the nvidia side everything worked perfectly and Surround was etup very quickly.
However on the AMD side i'm having issue. When i go into catalyst and attempt to set up eyefinity it only duplicates all of my screens then ask my "to continue start a new task.
Are my adapters the problem:
1440x900
Displayport->vga
Displayport->vga
1600x900
no adpater- DVI
Thanks
Ah! I get it now. Sorry for my weak reply. To answer your question, that is because Eyefinity requires the same resolution monitors in order to work, you can however extend different resolution monitors for normal desktop/application use.
I want you to try this; Update your video driver, and change the resolution of each monitor so that they all match eachother, and see if you can somehow trick Eyefinity to work.
@Suzuki Yeah, when I click on the display i want to use as the first step of eyefinity. once i click on 3x1 it will proceed to next slide where it will mirror the same display onto all 3 monitors.
My aim is not to use each display seperatly (as i have already done that) i want to run them in eyefinity. thanks
