AMD FX 6300 voltage problem
JohnPD99
Commendable
Apr 10, 2016
Hi,
I'm new here. I have overclocked my FX 6300 up to 4 Ghz. I tested it for 45 minutes on prime95 and it passed without any problems. The weird thing though were my voltages. My stock voltage was at 1.15 v (really low, usual stock voltage for FX 6300: 1.35 v).So I put it up to 1.24 v(still low). Like I said it run fine. During the prime95 test i looked at the core voltage and it said 1,176v!! And when i did normal tasks on my computer it said 1.24 v. Can someone tell me the problem? I would be really thankfull. If there was a solution, should I change it or just leave it, because it's running fine already.
John
It sounds like you're running into Vdroop. This is where the voltage across the CPU drops while under load due to the CPU requiring more power. These inconistant voltage drops can sometimes cause crashes if the drop is big enough that the CPU now doesn't have enough power.
Overall, if your OC is stable: don't worry about it. But if it bothers you, or if you want to overclock farther, look for a setting in your BIOS called "Load Line Calibration" or something similar (Varies between manufacturers). What this does is it allows your motherboard to realise when the voltage being provided is dropping from Vdroop and allows it to compensate by temporarily bumping how much voltage it can provide.
Obviously, I'm skimming details. Check out...
Obviously, I'm skimming details. Check out other forums and google around a bit to learn more, but that's the gist of what you're experiencing.
Thanks a lot!! I will try my best.
