AMD Radeon HD 7450 problems.
Bamsehop
4
i just installed Windows 7 on a HP Pavilion p6-2310eo Desktop.
i downloaded all the drivers and got everything to work except the graphics card.
the graphics card is a AMD Radeon HD 7450.
i have tried downloading the Driver but it still just show Standard VGA in Device manager.
i have tried following these steps from another tread.
(I have fixed this problem now,thank you for your help.
If someone is struggling with a same,or similar problem,this is how i fixed it.
Though this method wont install any AMD graphics control panel thingy.
Alright so,first i went to the Device manager and checked,it was Standard VGA cable.
I shutdown the system,went to setup(F10) ,then to advanced and switched my primary video adapter to PCI-E
Restart,still it was standard VGA,so i went to device manager,right clicked the VGA,and clicked update,then manual browsing.
Then,i downloaded the new beta drivers by AMD,clicked the Have Disk,button in update drivers,and selected Display > xxxx.inf and then it gave me a list of display drivers.
Just simply chose mine,restarted and voila! Works like a charm.
But there is no Graphic Properties thingy,thats sad.)
the only step i did not do was switching the primary video adapter to PCI-E.
there is no place is show me i can switch it.
i need help if anyone know a solution.
try installing the ati drivers from Hp ( im on dell but whats different my gcard aint working if not from dell )
and , should be it , any probs , ill help if i can :)
thanks for the anwser i found a solution some time back.
the problem was the HP Pavilion p6-2310eo original came with Windows 8.
on the HP site it only had drivers for Windows 8 and 8.1 and they just dident work on Windows 7.
i found a driver for a other HP computer with same graphics card and wich orginal came with Windows 7 on it.
Sorry if my english is bad or hard to understand. I'm from Denmark 😛
Thank you, this appears to be what we are looking for too.
