Thank you for the explanation. I didn't know such wire can sustain even 100A. I thought it's like with starter cables. Bigger diameter means no power loss and you won't melt the cables.
If the cables were really long, there would be an issue with that much amperage, on such a thin wire connection. The longer the cable, the thicker it needs to be. Learned that the hard way, when I used to have a camper, on AC, and have experienced it in DC applications, on my boat, with regards to the trolling motor. Due to where my battery was, on the boat, vs where the motor mounts, at the time, I needed to run thicker cable, vs now where my batteries are fairly close to the motor. Corsair decided to go with thicker wire, for their PSU cables, with the new connector. Pretty sure it's a solid core.
View: https://www.youtube.com/watch?v=dbT84gxKnMA
