cangelini :
Around front, similar-looking slits decorate the expansion bracket. Of course, because the heat sink's fins are oriented vertically, these do nothing for ventilation since hot air exhausts out the card's top and bottom.
I wouldn't say they do "nothing". Air is still going to be entering or exiting the case through them due to pressure, which should help reduce buildup of warm air around the card, even if the card itself isn't actively forcing air through them. For a card that produces as much heat as this one, any additional air circulating around the card undoubtedly helps.
Brian_R170 :
Worlds first 7nm gaming GPU... that consumes 66% more power than the competitor's slightly-higher-performing 12nm GPU. Is it a reflection of AMD's architecture, TSMC's process, or a little of both?
It's probably at least somewhat a reflection of your math being off. : P The 2080 draws around 220 watts under load, which would place the Radeon VII's power consumption at around 35% higher. Aside from that, it's probably due to the fact that this GPU actually only has a core count that's in-between Vega 56 and 64, and AMD overclocked it to its limits to get that extra performance. This is ultimately just Vega on a smaller process, or in other words, re-purposed professional compute hardware. Some of its features, particularly the 16GB of HBM2, don't really benefit gaming performance much, but are very expensive, so they can't sell the card for less than the competition. With a similar-performing chip built to utilize 8GB of GDDR6, they could have likely sold it for around the price of a 2070, where it's performance could be a lot more compelling, and they wouldn't have had to push the card to it's limits, keeping the heat and noise more reasonable. Vega was built around expensive HBM though, so they're stuck with that, at least until their next generation of high-end hardware is ready. Navi will likely fare better, but that will probably only cover the mid-range, while a Radeon VII successor is likely at least a year away.
delaro :
The only thing this is showing me is how much of a value a 1080 TI used "$450-$525" has.
Unless the thing fails shortly thereafter and it's not covered by warranty and you're out $500. : P I would personally want a good 3-year warranty on a card in that price range. Even a new 2070 for $500 would arguably be preferable, even if it doesn't perform quite as well.
King_V :
While I don't think wccftech made up this interview . . I'm a bit leery when the info is coming from a single anonymous source, not confirmed by anyone else, yet is seen as dead-on reliable.
I mean, don't get me wrong, could well be true. Could well be somewhat inaccurate in the estimation of the costs, though.
I suspect that information was likely reasonably accurate, though it's possible that some things could have changed since then. Maybe the card was originally slated for release somewhat earlier, when it might have cost a bit more to produce, or maybe they originally planned to give it a liquid cooler, which would have added to the price. I'm sure their margins must be quite low though, due to that huge amount of HBM2. You can be pretty sure that if AMD could have sold this card for less than the 2080, they most likely would have, as it would have been better received. And the whole point of that article was about reasons why AMD supposedly got rid of that executive after only being with the company for less than a year. Also worth pointing out, that particular executive used to work for Nvidia, so make of that what you will. >_>
justin.m.beauvais :
I hate how overclocking has gone from an option to an expectation...
In some cases it can be a decent option. The Ryzen 2600 or 2700, for example, can be overclocked up to a similar performance level as their higher-clocked "X" counterparts, and have been priced low enough most of the time where even if you replace the stock cooler with something better and quieter, you can end of paying less overall. So, overclocking there can be a way to save a bit of money to put elsewhere in a build without sacrificing performance, particularly if you wanted to replace the cooler anyway. That seems to be a trend with AMD's lower-priced versions of chips. Intel locking overclocking to higher-end hardware is a bit more questionable, but I can see why they do that. As for graphics cards, factory overclocks have been the norm for a long time, and in general, cards with moderate overclocks don't tend to really cost more.
nobspls :
This is such desperate attempt at puffing up the VII. If you think VII is in the "ballpark' then the 2070 is in the ballpark too. See:
So they should be priced "ballpark" around a 2070. Why shouldn't they release it around the 2070 prices?
Seriously, weaselly slippery words like "ballpark" is just a poor excuse for sleight of hand tricks and self-delusions.
Wow, that chart you posted shows the Radeon VII's 1% Lows performing better than even a 2080 Ti, and 0.1% Lows coming close behind, with both well ahead of an overclocked 2080. Most impressive. You must really love Radeon VII to show it outperforming the competition where it really matters. : 3
