Question AMD Ryzen 2200G max DVI port resolution
bmandl
5
I have AMD Ryzen 2200G processor on gigabyte b450m ds3h motherboard with dual monitor setup, both WQHD. On first, that is hooked up on my HDMI port, I can get desired resolution (2560x1440), but on second, I can only get 2048x1152. Is this the limit of APU or motherboard or something else? Will I solve problem if I update to newer CPU and which one?
Thank you.
So, after some googling, I believe, I will have to replace motherboard and this is all I can find in m-ATX format with DisplayPort and HDMI:
  1. Asrock B550M Pro4
  2. Asrock B550M Steel Legend
  3. Asrock X570M Pro4
If I get one of those motherboards, I will also have to replace CPU, because none of those supports my Ryzen 3 2200G. I am looking into Ryzen 5 4600G or Ryzen 5 5600G. Are there any other similar motherboards, possibly Gigabyte?
