Question AMD Ryzen 5 3600x problem
Aug 26, 2020
4
Hello! So recently i decided to install an app to monitor my CPU temperature in order to see if it gets overheated and i discovered a wierd problem. (i'm not even sure if it is a problem that's why i'm making this topic).
As you can see in this picture : View: https://imgur.com/a/q2NTgRh
, one of my cores is premanently at 50% load, but when i'm opening task manager and leave it open on the other monitor, that loading drops and so does the temperature : View: https://imgur.com/qUvZfE4
Basically when my task manager isn't opened the temperatures in idle are staying at around 47, and when it is opened at around 38-39.
How does this problem occur?
(P.S Sorry for my bad english, i'm still learning)
Prad_Bitt
Upstanding
Jul 4, 2020
474
81
290
14
Don't use any software other than Ryzen Master for temperature and clocks. And Task manager for CPU usage. Everything else is glitchy with ryzen. HWinfo is good too
