The scheduled forum maintenance has now been completed. If you spot any issues, please report them here in this thread. Thank you!
What Thermal Compound application method would you recommend for the Ryzen 9 3900X (Vertical Line, Middle Dot, etc)?
Okay, I know I'm late to the party, but why did you test a high end system with VRMark Orange Room? This is not a true test for a CPU and GPU! It's just to determine if the system is VR Ready!
From VRMark Developer UL_Jarnis over on the Steam Forums:
"Orange Room, quite true, is not a normal benchmark. It is intended only to figure out if you meet the minimum requirement of the HMDs. It gets CPU limited real fast. It is NOT a graphics card performance test. It is not intended to be that. So comparing two PCs to each other with it is not what you should be doing. The documentation does tell you this, but after almost 20 years of 3DMarks, I can see how it is easy to miss this fact.
Blue Room and Cyan Room are just as much "proper benchmarks" as anything, they are purely GPU-limited so will scale well and specifically test performance in rendering VR. This specific thing does mean that they only scale to two GPUs in multi-GPU, but this is the limitation of VR APIs as they do not support 3+ card configs - and in all honesty vendors are phasing out 3+ GPU multi-GPU configurations. 2080 for example can only be set up in 1 or 2 card configuration at all. "
What "home user" software do you find speed lacking and experience can be improved by and only by faster cores?A 12 core CPU will not be any faster than an 8 core for home users. The software used does not scale with that many cores. If it was so easy to make typical software scale with more cores, programmers would have already done it. Most mainstream software is not capable of being highly parallelized like a graphics workload, so this problem isn't going to get fixed without a completely different type of computing platform. Adding more cores doesn't make a PC faster when what you really need is faster cores.
You don't have to. Both are single threaded applications with random addons that may support multithreading, so you know Intel is going to win, just like most stuff from Adobe. People like Ncogneto don't seem to grasp how much commonly used software doesn't benefit at all from increased core counts beyond a few.
Ryzen 3000-series chips are compatible with most previous-gen motherboards with the AM4 socket, but some updates are left to vendor discretion. As such, you won't be able to drop a new Third-gen Ryzen chip into all X370 and B350 motherboards, and A320's upgrade path is blocked entirely. Due to the uneven application of BIOS updates across the various vendors, and even among different motherboards in the respective product stacks, you'll have to check the CPU support list for your X370 or B350 motherboard to ensure it supports Third-gen Ryzen.
It says "Nvidia GeForce RTX 2080 Ti". Is it from ASUS, Gigabyte, MSI, Nvidia, or what company? Is it just a Founders Edition?AMD's Ryzen 3000 series promises more performance and value via the benefits of the 7nm process and Zen 2 microarchitecture.
AMD Ryzen 9 3900X and Ryzen 7 3700X Review: Zen 2 and 7nm Unleashed : Read more
Why would that matter?It says "Nvidia GeForce RTX 2080 Ti". Is it from ASUS, Gigabyte, MSI, Nvidia, or what company? Is it just a Founders Edition?
Isn't Founders Edition a Nvidia.com only card? It matters as different cards have different speeds and cooling ablilities.
