Hi all. I have a pc with ryzen 5 3400g cpu. I noticed that minimum processor state is 90% at AMD Ryzen balanced plan. But in Windows balanced plan the minimum processor state is only 5%. The pc hove sometimes problem at shutdown. sometimes it stuck in blue monitor (shutdown monitor) and It needs hard reset then. So I think if minimum processor state at 90% overheat the cpu and if it is a reason for shutdown stuck (like freeze). I would like your opinion. I use the pc for office, aytocal (not games). It is good to try to set minimum processor state at 5%? Or this cause other problems? Thanks!
