Question Amd ryzen master killed my pc Please Help
7
Hi everyone i used amd ryzen master game mode and now im stuck with a pc that not posting anymore .
This is my setup:
Cpu: amd ryzen 5 2400g
Ram : adata 8gb 2666hz single channel
Mobo: asus a320m-a
Psu: green gp530a-eud
Gpu: msi nvidia gtx 960 4gb
I've tried this steps too but nothing:
1.removing cmos battery for more than an hour when there is no power connected to the psu
2. Swapping ram stick sloth
3. Removing gpu and cpu and connecting them again
4. Removing every USB or Either connection but still no gain
When i press the power button the system turns on but there is no posting beep and no picture on monitor
Please help everythings was working fine i don't know why i do that it was my first decent pc and i ruined it in less than a year . (T-T)
This does exactly what shorting pins does...
Also, try and source a reliably build PSU from a friend or neighbor, something made by Corsair or the likes and breadbaord the system, see if you get to power at the very least.
*That PSU does not look like a good unit.
Even that exact model that i replying to you?
This is my setup:
Mobo: asus a320m-a
Since you have an apu, you dont need a gpu. Unplug the gpu entirely, remove it from the slot and try again. Also try again with 1 stick of ram.
