[SOLVED] Amplifer and car audio head unit settings
Jan 28, 2019
Here is the link to my Alpine amplifier details. https://www.crutchfield.com/S-3h9XE9pyw05/p_500MRPM450/Alpine-MRP-M450.html I have a 10 inch 400 watt RMS kicker subwoofer What should my gain , my bass EQ, and my LP filter be on for best sound and bass. And I also have amp gain on the JVC car head unit, here is the link to the JVC which also has bass gain from -5 to +5 and 13 band equalizer. what should I set that gain on along with bass frequency on 13 band equalizer http://www.us.jvc.com/car/multimedia/kw_v230bt/ I busted the subwoofer and waiting for its replacement. Even though it is a good quality subwoofer that handles the amount of power the amp is pushing. I alos have a bad habit of not turning the head unit down when getting out fo the car. and it being that high volume when I start car. Maybe that is the problem .If you can help me wiht this it would be appreciated
Latest posts
