Heya out there.
I start with my problem that I have been trying to fix for a decade. The problem is related to Far Cry 5 with my custom built PC.
The problem is that I have been experiencing loss in performence in the game with my PC. I cannot make up my mind if its the PC itself nor the game (which I highly dont doubt it could be).
What I tried so far in the following list
- Clean install of Windows 10
-Updating GPU driver and reverting back to older versions
- Overclocking CPU without good results
-Turning off SMT in BIOS
-Turning off Core boost in BIOS
-Changing power plan in Windows 10 between balanced, high performence and AMD's powerplan
-Checking temps. CPU is around 35 to 50 degrees in C. GPU are similiair in the degrees, just a bit higher. MOBO temp is on 40 C. So I wouldnt believe that could be the issue.
-Changing from Normal priority to High in Task Manager
-Reinstalling game
-Updating chipset
-Updating MOBO
-Disabling useless settings in Windows 10
-Moving the game to a SSD
-Turning down video settings in the game without difference
PC SPECS:
CPU: AMD Ryzen 5 1400 3,2Ghz OC'd to 3,4Ghz
GPU: NVIDIA GTX 1050 TI 4GB, not OC'd
RAM: 1x8GB 2400Mhz DDR4 in Dual-channel, not OC'd
MOBO: MSI B350M GAMING PRO AM4
SSD: Samsung 860 Evo on 256GB (WIndows located)
HDD: Seagate on 2TB for most of my games
PSU: Corsair CX450M
FUN FACT
I were recently over by one of my friends for a lan party, since its been a while. We mostly discuss about PC parts and on-going PC development. I knew that we both had a very simalir PC and came to me that he should try out Far Cry 5 on his PC. I wanted to see if there were a difference in that game on his PC by its performance. It turned out that it ran perfectly on medium settings with steady 60FPS. I can barely keep up with 35 FPS, but he also got Intel that I should remember in the background. But what we got in common is that we both got the exact same graphics card, single-channel RAM and a CPU with 4 cores. He's CPU is a i5 from the fourth generation, but Intel is also known to be best suited for gaming.
Just wanted to tell that also in this thread
Thanks in advance
-Reinstalling game
-Updating chipset
-Updating MOBO
PC SPECS:
PSU: Corsair CX450M
FUN FACT
Thanks in advance
