AN35 Ultra and dual channel question
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
hi all,
i bought two sticks of Kingston ValueRam 2100 a while back, and
decided to use them on this board in dual channel setup. well, one of
the sticks went bad, so i RMA'd it back to Kingston. the question is,
will the replacement mess with the dual channel? the tech person said
they couldn't find one with the same "run" or "batch" number, but it
should work fine in dual channel configuration. i'm kinda a neophyte,
so how will i even know if the new stick is running in dual channel
with the old stick?
thanks.
I had no problems with two sticks of ValueRam from two different stores
bought months apart. You should be OK.
mc
"XB" <parlay@myway.com> wrote in message
news:ca9fe839.0406180745.1da7093b@posting.google.com...
> hi all,
> with the old stick?
> thanks.
