[SOLVED] Annoying RPM Problem and High Temps with H115i [6900K]
Jan 28, 2019
6
Hi, I have Corsair H115i water cooler installed on intel 6900K. I'm using corsair link software for control fan speeds. Right now it's on balanced profile and my idle temp is 55C. It's loud also(2280RPM for fan and 2040RPM for pump). When i post this thread my temp keeps increasing now it's 70C. I don't have enought knowledge about water coolings. I will add screenshot too it's connected to cpu_fan i guess. Maybe it will be wrong because cpu_pump socket is empty. I will appreciated for every comment. Thanks!
Screenshot : https://imgur.com/a/iWwBGqu
your lowest temps will be only when coolant is at room temp, and, naturally temps will rise to higher levels under a gaming load, maxing out (hopefully) at higher levels as fluid heats up somewhat. Temps of 70C under a heavy load is nothing to be overly concerned over, as long as temps level off below 80C or so...; if they keep climbing, then you'd be experiencing thermal runaway...(probably not an issue with that cooler and CPU)
I would be happy 70C on heavy load but it's idle. I have %2 CPU load and it's working between 1.35 GHz - 1.54 GHz.Right now my cpu temp is 70C. I'm using AIDA64 for check temps. Fans running at 2280 RPM and it couldn't lower the temp. Is 3 years enough for thermal runaway ?
I did it. Now pump RPM is 3150. My idle temp decreased to 55C. It's not bad but still very loud for idle state.
It's almost 3 years now. Sorry my english isn't good enough. I don't understand what do you mean with slowly work up ?
Now it's fixed around 55C at idle. When i play game it's increasing slowly. There is no sudden increases or decreases.
